Correct way to program ports on 16F628A - Help
S
Syd
I am trying to learn PIC assember.
Can someone please give me the correct assembler code to program a
16F628A with all pins on PORTA and PORTB as outputs and then toggle
them Hi and Lo.
My efforts to date using MPLAB has always resulted in an error.
Syd
P
Peter S. May
them Hi and Lo.
Syd
If it were the 16F88, I'd be able to help, because that's what I have.
Either way, it seems as if the following might be a lead to what you
want (one of the programs does exactly what you asked for):
http://www.winpicprog.co.uk/pic_tutorial1.htm
Don't fear the Google.
PSM
A
Anthony Fremont
them Hi and Lo.
Here is some code that will toggle the output pins at quite a clip. IT IS
UNTESTED, but was cut from working code, so it should work fine. ;-) I
assume a 4MHz external crystal is connected. Watch out for line wraps from
the comments when you copy and paste this code.
; HEADER:
LIST P=16f628
RADIX DEC
INCLUDE "p16f628.inc"
__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _PWRTE_ON &
_BODEN_OFF & _LVP_OFF
; EQUATES:
STARTOFRAM equ 0x20 ;First Usable RAM Location for
16f628
ENDOFRAM equ 0x6F ;Last Usable RAM Location for
16f628
FIXEDAREA equ 0x70 ;Start of shared memory
between banks
BANK2RAM equ 0xA0 ;Start of Bank 2 RAM
; General Purpose Temp Storage
cblock STARTOFRAM
LoopCounter
endc
; Common Area Temp Storage (visible from any bank)
cblock FIXEDAREA
; ISR Register Context Save Areas
INT_FLAGS
W_TEMP
STATUS_TEMP
FSR_TEMP
PCLATH_TEMP
endc
; START:
org 0x000
goto Start
; Interrupt handler
org 0x004
movwf W_TEMP ;Save everything
swapf STATUS, W
movwf STATUS_TEMP
movfw FSR
movwf FSR_TEMP
movfw PCLATH
movwf PCLATH_TEMP
goto IntExit
; Restore everything and return
IntExit
movfw PCLATH_TEMP
movwf PCLATH
movfw FSR_TEMP
movwf FSR
swapf STATUS_TEMP, W
movwf STATUS
swapf W_TEMP, F
swapf W_TEMP, W
retfie
; Main level code begins here
Start
bsf STATUS, RP0 ; Switch to Bank 1
movlw b'00000000' ; Define I/O on Port B (all
output)
movwf TRISB & 0x07F
movlw b'00000000' ; Define I/O on Port A (all
output)
movwf TRISA & 0x07F
bcf STATUS, RP0 ; Back to Bank 0
movlw 0x07 ; Turn off the comparators
(common newbie mistake to miss this)
movwf CMCON
clrf PORTA ; Drive all pins low
initially
clrf PORTB
Main
; Drive the pins high
movlw 0xFF
movwf PORTA
movwf PORTB
; A couple of no-ops to square up the output waveform
nop
nop
; Drive the pins low
movlw 0x00
movwf PORTA
movwf PORTB
; Loop back forever
goto Main
end ; Don't forget to include
one of these
A
Anthony Fremont
Anthony Fremont wrote:
I posted the program to alt.binaries.schematics.electronic as an attachment
since OE wrapped a bunch of the lines.
