Correct Formula For Bypass & Coupling Capacitors
Discussion in 'General Electronics Discussion' started by jdpbba79, Sep 10, 2019.
  1. jdpbba79
    jdpbba79
    Aug 26, 2019
    Hi:
    Can someone advise which formula to use for computing the value of bypass and coupling capacitors
    for amplifiers. Some sources say that a 0.1 factor should be used as shown below while other sources
    do not use the 0.1 factor.
    C = 1 / (2 * π * f1 * Zin * 0.1)
    C = 1 / (2 * π * f1 * RE * 0.1)
    C = 1 / (2 * π * f1 * RL * 0.1)
    Thanks in advance.
  2. Harald Kapp
    9,380
    1,912
    Without knowing where in the circuit these capacitors sit and what the other parameters are, it is next to impossible to judge the equations. Please supply a schematic and the relevant parameters.
  3. kaigamo
    kaigamo
    Sep 10, 2019
  4. jdpbba79
    jdpbba79
    Aug 26, 2019
    Hi Harald. Here is a sim.
  5. Harald Kapp
    9,380
    1,912
    Which C are youi asking about?
