EastCoastToast
- Dec 21, 2015
- 26
- Joined
- Dec 21, 2015
- Messages
- 26
Hey guys, I've recently bought a hot plate for about $50 in hopes of repairing it for use. These generally are about $400-500 so it's worthwhile to attempt to fix it.
The circuit is composed of two PCBs. One which is connected to the power supply contains a triac, a transformer, a relay and the inputs/outputs for the motor and heater with various resistors and a component to determine rpm of the motor.
The second PCB contains a micro controller and the turnable joysticks that control the range of heating and motor speed.
I have a limited working knowledge of circuits. I've taken one course and messed around with 7 segments and disposable camera tasers. I'm not sure where to start with this repair and was wondering if anyone has any advice/suggestions.
I have researched a few things, another posting talked about determining the resistance of the heater to determine whether it was broken or not. I tried and couldn't get a solid connection. Also the PCBs are made by ACT Corp of Rowlett,Texas.
I was able to get the unit turned on and the motor turned the stirrer. I turned the heat on, heard a click and then turned off the heat and the stirrer no longer turns and the light doesn't come on when the heating element is on.
Thanks for taking the time to read this!
