core saturation
Discussion in 'Electronic Basics' started by [email protected], Jun 22, 2005.
  1. Guest
    I was just thinking about core saturation and how it might be
    detected/measured and I remembered something about current transformers
    being ruined if they were allowed to saturate. Am I remembering
    correctly? Previously I had been thinking that saturation was a
    harmless event -- if currents were limited. Yes or no?
  2. John Larkin
    John Larkin Guest
    You can magnetize a CT by running it without a burden resistor, and
    that will subsequently mess up low-current accuracy. But it's easy to
    demagnetize it and fix it.
    In an extreme case, I guess you could arc it over or something, but
    that's not common.
  3. Core saturation is normally a reversible process.
  4. Rich Grise
    Rich Grise Guest
    It doesn't ruin the transformer - it ruins the waveform and you get
    an inaccurate answer.
    And in a current transformer application, the primary current is limited
    by the load itself, so that's certainly not a problem, but do pay
    attention to that burden resistor! :)
    Good Luck!
    Rich
