cordless phone help
A
al
I have a uniden cordless phone 2.5Ghz handset. The handset is not
talking to the base, i.e. no dial tone it turns off after few beeps.
I have checked the voltage coming out of the battery and it is OK.
The base is working fine and have dialtone and can make phone calls
normally. Also the intercom/paging feature does not work. Any
pointors as to what problem could this be?
TIA
James Del Mul
Try unplugging the base for a little while. That sometimes resets everything
and then the base will "see" the handset.
Also check the manual to see if there is a way to program handsets to match
the base.
