N
Neil Green
Hello all.
My old cordless phone needs a new battery.
I have a good battery here rated at the same voltage
(3.6V), but it's a 300mAh NiCad battery, and the one
in the phone is a 600mAh NiMh.
The batteries are the same physical size, I only need
to adapt the plug on the good battery to fit the
phone.
Can I use this battery in the phone?
Will the charger in the phone charge the same for the
NiCad as the original?
I assume that the 300mAh battery will just give less
talk/standby time than the 600mAh but should operate
the phone OK, my only concern is the charging.
Any advice appreciated.
phone.
