cord pulled out of reader writer
Discussion in 'Troubleshooting and Repair' started by dcntma, Oct 16, 2018.
  1. dcntma
    dcntma
    3
    Oct 16, 2018
    my usb plug that is connected to the pcb board got yanked out! now here is the dilemma. the board has 4 solder points and the usb has five wires,1 black 1 white 1 red 1 green and a bare wire no color?
  2. Harald Kapp
    10,212
    2,201
    Welcome to EP.
    Your pictures could be more crisp.
    The USB color codes are explained e.g. here. The bare wire could be shield. To ensure correct assignment of the wires to data and power, simply check with a multimeter in Ohm range between the bare ends of the wires and the other end of the cable where the USB plug should still be connected.
  3. dcntma
    dcntma
    3
    Oct 16, 2018
    what should the ohm range be
  4. Bluejets
    Bluejets
    4,150
    878
    Oct 5, 2014
    R x 1.
    What you are looking for is continuity to see which wire is connected to which pin as Harald said.
    You could use the buzzer if it has one.
  5. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    ....and I wouldn't, for one minute, contemplate soldering those wires back as they are! Trim them properly.
  6. dcntma
    dcntma
    3
    Oct 16, 2018
    Okay I got everything soldered back on I got a blinking green light and it doesn't say unrecognizable usb now it has question mark by universal serial usb
  7. kellys_eye
    kellys_eye
    4,276
    1,146
    Jun 25, 2010
    Needs an updated driver.
