Copper tape?
Discussion in 'Electronic Basics' started by DaveC, Apr 27, 2005.
  1. DaveC
    DaveC Guest
    Need some thin copper tape (adhesive foil), about 1 or 1.5 inches wide, about
    16 inches long.
    I'd be willing to buy a roll for this one-time use, but all I see is the 3M
    stuff at $30-plus. Samples from vendors seem to be a thing of the past.
    Is there any non-3M tapes available?
    Please, no "Go Google this" replies. I wouldn't
    ask a question here if I hadn't done that already.
    DaveC
    This is an invalid return address
    Please reply in the news group
  2. jim dorey
    jim dorey Guest
    http://www.chomerics.com/products/chofoil.htm
    http://www.can-dotape.com/foil-tape.htm
    http://www.venturetape.com/final/Shielding.asp
    searched metacrawler for 'copper foil adhesive', seemed to come up with
    something.
    metacrawler includes google searches, but doesn't suck on the(frequent)
    occasion that google will.
  3. EN
    EN Guest
    How about eBay?
    http://search.ebay.com/copper-tape_W0QQfkrZ1QQfromZR8
  4. John Larkin
    John Larkin Guest
    The stained-glass people use adhesive copper tape, but maybe not that
    wide.
    John
  5. tlbs
    tlbs Guest
    Does your application require copper? If it only requires a conductive
    tape, you might consider aluminum. Aluminum tape is usually available
    at hardware stores for use in duct-work.
  6. DaveC
    DaveC Guest
    Doh! I just never seem to think of e-Bay for components and supplies. Only
    for Digital Cams, Collector Dolls, and such. Dunno why... guess I'll get over
    that sometime.
    Thanks!
    DaveC
  7. DaveC
    DaveC Guest
    Great idea.
    Thanks!
    DaveC
  8. Si Ballenger
    Si Ballenger Guest
    If you need copper (maybe a need to solder on a lead), check your
    local craft store. They usually have thin sheet copper for crafts
    which you could attach with two sided tape.
  9. Rick Fox
    Rick Fox Guest
    This might sound strange, but check out garden supply shops. Copper
    tape is used to put around plant pots to stop slugs crawling up them -
    they don't like copper!
    Rick.
  10. Barry Lennox
    Barry Lennox Guest
    I picked up some self-adhesive copper in "letter" sized sheets at a
    stained-glass shop. You can just cut it to whatever shape you need.
    Barry Lennox
  11. And again your cross-posted question proves you aren't
    using google much. You'd be better to practice using it
    rather than doing your corss-posting (which as I said
    before is a sign of not using google to find the best
    place to ask).
    A number of times, I just checked, I've mentioned that
    copper tape can be had where stained glass supplies
    are sold.
    So the information is "google-able".
    At least have the decency take out that silly signature,
    which is clearly not a statement of fact.
    Michael
  12. DaveC
    DaveC Guest
    Great idea! Thanks!
    DaveC
  13. DaveC
    DaveC Guest
    It is.
    "Delete" or "kill file" are options.
    DaveC
  14. Rich Grise
    Rich Grise Guest
    Well, notwithstanding crossposting has nothing to do with whether
    or not a google search has been done, crossposting is preferable
    to multi-posting for a number of reasons:
    http://www.dickalba.demon.co.uk/usenet/guide/faq_cros.html
    Cheers!
    Rich
  15. Lay awake at night wondering whether "anal retentive" is hyphenated, do ya?
    Jim
  16. Chris
    Chris Guest
    Hey DaveC, are you sure you haven't Googled, you wouldn't be telling a
    little lie would you ;-)
    I just did this -
    "copper tape" supplies
    - into Google and clicked on the first site and up came
    http://www.stewmac.com/shop/Electronics,_pickups/Supplies:_Shielding/Conductive_Copper_Tape.html
    there are plenty of others, 12,400 in fact, so I suggest you rid yourself
    of that pointless signature - and when you start using Google don't forget
    about the Groups section, where there are 78 hits for the same entry.
    Remember, whatever the problem you may have, you can bet your life that
    someone else has already had it and has already posted.
    see www.google.com
    Oh, I feel better now .....
    Cheers.
  17. DaveC
    DaveC Guest
    Simple is best. I was, apparently, Googling using too many terms, which
    limited my results.
    Always happy to have someone point me to a resulting URL, as you have done.
    Thanks!
    DaveC
  18. cougercat
    cougercat Guest
    Almost any garden shop sells this tape in 1 1/2 inch width for slug barrier.
  19. Chris
    Chris Guest
    Anytime.
    Try this Google exercise. Type anything into Google search and open up one
    of the many sites listed. Click on any link inside that site, and on the new
    page scroll down to some text and copy say about 6 words of text. Now go
    back to Google and paste it into the Google search bar inside " ". You
    should end up with only that site, or just a few. Repeat this exercise
    enough to convince you that Google has indexed possibly billions of pages.
    Once you understand that, it is possible to find just about anything with
    the right combination of text and text inside inverted commas put into
    search bar. And don't forget to use Images and News as well - the answer
    will be there - 99% of the time.
    Cheers.
