R
Roy McCammon
can anyone point me to a web site that gives resistivity of any typical
copper wire from about -40C to + 60C?
Roy said:can anyone point me to a web site that gives resistivity of any typical
Roy McCammon said:can anyone point me to a web site that gives resistivity of any typical
Robert said:Roy said:can anyone point me to a web site that gives resistivity of any
typical copper wire from about -40C to + 60C?
Off hand,
Resistivity @ 20C (<--I think)
rho = 1.724e-8 [ohm m]
Temperature:
R(T2)/R(T1) = (234.5 + T2) / (234.5 + T1)
where T's are in Celsius.
I believe this for annealed copper. The different forms of copper have
slightly different rho and temperature dependency constant.
Tom said:You can get the variation with temperature from
http://www.cda.org.uk/Megab2/ElecApps/pub122/sec11b.htm. That's from
a google search, and it's interesting to note that it shows a
relationship between Spehro's first method and Robert's. You can get
the resistance per 1000 feet of annealed copper wire at 20degrees C
for AWG gauge numbers amazingly closely from the very simple formula,
10^(0.1*AWG-1), so for 10 gauge wire, it predicts 1 ohm, and my wire
table says 0.9989 ohms and for 30 gauge it predicts 100 ohms, while
the table says 103.2.
Cheers,
Tom
Mike said:The 1922 Standard Handbook for Electrical Engineers provides a table of
values depending on where the copper is from and who measured it. Their
values, at 25C, are 0.380%/C to 0.386%/C.
By 1943, the Bureau of Standards had weighed in with 0.393%/C for annealed
copper and 0.382%/C for hard drawn copper at 20C.
-- Mike --
Spehro said:The tempco of resistance of copper is approximately +3930ppm/K at room
temperature, depending on how pure it is and upon annealing.
So R(T) ~= Ro * (1.00393)^(T-To)
Spehro said:No, compare to the values I gave below, I think you'll find at least a
couple percent difference. What are you up to? Copper RTDs are not a
"precision" way of temperature measurement, but they are used.
Roy McCammon said:I'm just trying to use a thermister to compensate
for the copper resistance in a coil. No doubt but
that your formula is good enough, but I'd still like
to see the "official" data.
Thanks Spehro. Any idea how accurate that that formula is
over -40 to +60?
