Jim Baber
I have heard or read of a means of refrigeration that uses steam
directed thru a venturi to directly cool with the reduction of pressure
at the venturi. It sounds feasible, but I can't recall where I read
about the concept.
Has anyone out in the newsgroup any knowledge of this. I seem to recall
this principal was used to make ice before electrical refrigeration came
into the forefront. It seems to me that steam created in the cooling of
the high temperature solar PV cells in solar concentrators could
actually be used to refrigerate an house or building directly from the
surplus heat that is typically dissipated with the water cooling
commonly used in this style of concentrator. This would increase the
efficiency of these concentrator style devices as far as useful work,
but would it not create more electricity. But, considering that the
temperature here at my house has exceeded 100 degrees for 31 days since
June 14th any cooling would be appreciated.
Just an idea, any comebacks?
about the concept.
