Converting Decibels (Db) to Signal to Noise (S/N)
Discussion in 'Beginner Electronics' started by KP, Nov 17, 2003.
  1. KP
    KP Guest
    Hi All
    I am abit stuck on converting a number in decibels (Db) to signal/noise
    ratio.
    I know the equation for converting into DB: -
    SN (Db) = 10 Log [Signal Power / Noise Power]
    The way which I have managed to conver the Decibel to S/N is using the
    following formula: -
    Inverse Log [XXXX db / 10]
    So using the above formula, 30 Db will work out to be 1000 s/n which is
    correct.
    The problem is, explaining how I got this formula. Any ideas or better ways
    of working this out would be appreciated.
    Regards
    Karl
