E
exxos
Hi all,
A simple switch uploaded here
http://www.aqtq39.dsl.pipex.com/temp2/switch.jpg
Bascially 100VDC unregulated supply rail. Drops 72V via a zener to power a
24V relay. Capacitor just to add some small smoothing to prevent the relay
from buzzing.
While the relay is turned ON, it connected the output to the 24V supply via
a 100K resistor.
When the relay turns OFF it shorts the output down to ground.
Sounds really simple, though I have been trying for the past 2 days to
convert this to a simple transistor circuit. To which after several attempts
given up so decided to ask here before I use the relay verson to see if
anyone can suggest a simple circuit which would do the same.
Chris
from buzzing.
a 100K resistor.
Chris
