Converting Between Decimal Binary Hex & Octal?
Discussion in 'Electrical Engineering' started by Louis Bybee, Oct 3, 2004.
  1. Louis Bybee
    Louis Bybee Guest
    Growing weary of manually converting between the Decimal, Binary, Hex, &
    Octal number bases I dusted off my old TI-83+ Calculator to see if that
    ability was included in its bag of tricks. Unless I'm missing something I
    couldn't discover any such ability. What would be slick is a similar
    function that's available in the scientific view mode of the calculator in
    W9x, and XP Systems, but without having to lug around a computer.
    What I'm after might require a program to be available with the TI
    Calculator?
    I would appreciate any suggestions.
    Thank you.
    Louis--
    Remove the two fish in address to respond
  2. Brian Reay
    Brian Reay Guest
    By a cheap Casio that does the job.
    You'll need to check model numbers, the one I use hasn't been made for
    years.
  3. I don't know about TIs, but several HP models can do that. I have a 48GX
    that can. I am sure the new 48 and 49 series can also.
    Charles Perry P.E.
  4. Buy an HP. My HP 49g+ does the conversions. It sells for $149 from Walmart
    on the Internet.
