Convert V to mV
Discussion in 'General Electronics Discussion' started by Electro132, Aug 6, 2013.
Thread Status:
Not open for further replies.
  1. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    Hi Guys,
    Thanks for the help in the past. Things with the other projects are going fine.
    I have a new project and it has to do with converting V into mV. I was thinking of having an input of 9V and converting it to an output of 80 mV.
    Can anyone help? This is hard to do.
  2. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    How much current do you need?
    if its not much then a simple voltage divider will work, though it will be a bit of a waste.
  3. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    I need to have an output of at least 80 mV so according to ohm's law
    I = V/R
    I = 0.08 / 10 = 0.008
    I = 0.008 Amperes
    I was looking online for something that could give me the resistors, caps and other stuff for the circuit but came close to nothing. So far the net has told me to use a voltage regulator lol
    But i'm having difficulty trying to convert it from either 3v, 12v or 9v to get 80mV (0.08 V)
  4. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    while your math is correct you are solving the wrong formula.
    I was asking how much current that you needed to base what resistors to use (the more current you need the larger the wattage and lower the resistance needs to be)
    in order to get .08V out of 9 you need a ratio of about 112.5 : 1 so theoretically you need a 111.5 ohm resistor then a 1 ohm resistor in series with each other and you tap right in front of the 1 ohm.
    9*(1/(111.5+1)) = .08V
    but being a strange number you would be more likely to go with either a 100 or a 110 ohm which would leave you with .09 or .081 respectively, either of which would probably work.
    This would also only leave you with .08A approximately, so if you need more than 80mA of current you are going to have to use smaller resistors.
  5. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    Not sure yet how much current. Btw, What do you mean by 'tap' and how do i do that technique?
  6. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    Thats just a term I use, you will have 2 resistors, the larger of which will go first you want to connect what you need to supply the 80mV with after the first resistor or before the second
    +V--->110 ohm----->1 ohm ----> -V/GND
    V​
    Part needing 80mV​
    Drawing didnt work perfectly but I hope you get the idea
  7. CDRIVE
    4,960
    652
    May 8, 2012
    If the first guy to use ASCII art is still alive I'd like to whack him with a bat. If he's dead and gone I'd like to dig him up and whack him with a bat anyway! :p
    Chris
  8. BobK
    7,682
    1,688
    But that would be cruel and unwarranted. When the first guy used ASCII art, there were only fixed width fonts. It is the proportioanal fonts that screwed it up.
    By the way, I was one of the creators of the classic ASCII animation of Bambi vs. Godzilla.
  9. BobK
    7,682
    1,688
    How about telling us what you want to do with he 80mV?
  10. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    Thanks the drawing is fine, but don't i need a diode just in case the battery is placed in the wrong way? Also, the current i am seeking is - 80 mV not + 80 mV.
    So i think the current for this is something like 0.1 - 0.3 but i want to use this current like a radio station so it's like the current 0.1 being transmitted within a range of 10 kilometres. Can you help me out?
  11. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    Well i want to project it out within a range of 10km kind of like a radio station sending out their signal.
  12. CDRIVE
    4,960
    652
    May 8, 2012
    Is that the one where Godzilla's big foot crushes Bambi?
    Huh? What does that mean?
    Chris
  13. (*steve*)
    25,496
    2,837
    I guess the next question is "how do you intend to do that?".
    80mV is an itty-bitty voltage that, on its own isn't going to do anything. If this is the input to some transmitter then needing 80mV DC seems odd.
    I think what we're getting at here is that you may have some other problems down the line and that "needing" 80mV is a symptom of that.
  14. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    No, no actually it is the output - - 80 mV is the output. The input is - well i set it at 9v. This is possible isn't it? i could go higher but not too sure right now
  15. (*steve*)
    25,496
    2,837
    Can you explain how that itty bitty DC signal is going to be "projected out"?
    I'm pretty sure you don't understand something, and if you explain what you're thinking we can tell you where that misunderstanding is.
  16. davenn
    davenn Moderator
    13,833
    1,950
    Not with the way you have described so far
    What EXACTLY are you trying to achieve .... full description
    cheers
  17. Electro132
    Electro132
    261
    3
    Feb 12, 2013
    Ok, ok. Here's the experiment i'm doing: To emit and receive a signal between the -70 mV and -80 mV range using pulsated LD's.
    Now i know it might sound crazy, but apparently it's possible
    That is the full description. That is why i wanted to convert 9v or some other source between -70 and -80 mV
  18. CDRIVE
    4,960
    652
    May 8, 2012
    So you want to setup a 10KM Laser Diode transmitter - receiver? I still don't see how your question relates.
    By the way, Lasers are "Line Of Sight" devices. Have you considered the following limitations?
    http://www.ringbell.co.uk/info/hdist.htm
    Chris
  19. BobK
    7,682
    1,688
    Yep, I did that. It was based on an actual cartoon of the same name that I saw at an animation festival.
  20. Harald Kapp
    11,513
    2,651
    I don't know any laser diode that operates from 80mV. I'm sure you have gotten something wrong - conceptually. If you want to measure a signal in the range of 80mV and transmit the measurement using laser diodes, you'll have to modulate the Laser diode current in a suitable manner and you will have to demodulate accordingly on the receiving end.
    By what means ever you are going to transmit the signal: The larger the input signal, the better the transmission. Arbitrarily reducing an input of 9V to 80mV for transmission is contra-productive.
Thread Status:
