Convert Subwoofer System AC220V-240V to 110V in US
Discussion in 'Electronic Repair' started by gritsaregood, Aug 21, 2006.
  1. gritsaregood
    gritsaregood Guest
    I have a small subwoofer system that is AC220V-240V, 50/60Hz. I do not
    know how many watts the system has.
    The system is stand alone, with a woofer and two tweeters, and you can
    plug an ipod directly into it for nice sound quality. It is not meant
    for use with a surround stereo system.
    I was hoping to convert the plug to US-style for 110V, but am not sure
    if I need any other converter or other interface.
    Could any one please let me know if I will blow this system if I
    convert the plug to AC110V and use it in the US?
  2. Probably won't work. Try a video store run by foreigners (East Indian or the
    like) for a step up transformer. Cycles are no problem.
    http://www.hammondmfg.com/
    http://www.hammondmfg.com/298.htm
  3. James Sweet
    James Sweet Guest
    What sort of power supply does it use? If it has a transformer you can
    hope it has multiple primary windings or taps, otherwise replace the
    transformer or use a stepup transformer. If it has a switchmode PSU then
    it's usually configurable with a jumper.
