Convert output to input
Discussion in 'Electronic Basics' started by John Popelish, Apr 2, 2007.
  1. A pair of resistors connected in series across the output
    will allow the voltage to be reduced by any amount desired
    across the grounded resistor.
    Do you want to reduce a speaker or line output to a mic or
    line input?
  2. Sorry. For some strange reason, I assumed that you were
    talking about audio signals, not video.
  3. Guest
    Hi i was wondering if there was any way to convert a output connection
    on a laptop to a input connection? is there any device i can buy to do
    this?
  4. Guest
    im trying to connect a xbox to my laptop screen. i bought a vga cable
    made for xbox but now my computer says i cant connect it
  5. Puckdropper
    Puckdropper Guest
    wrote in
    What you'll need to do that is a video capture device of some kind. If
    your laptop wasn't designed to use the VGA port as input, you'll never
    get it to do so.
    You probably won't need the VGA cable, the capture device probably won't
    support it. You'll have to use SVideo and/or composite.
    Puckdropper
