Convert from 4 to 8 ohms
Discussion in 'General Electronics Discussion' started by CMarangon, Feb 3, 2013.
  1. CMarangon
    CMarangon
    14
    Feb 3, 2013
    Hello!
    I bought an used Sony Home Theater model STR k660P able to reproduce a six channel surround sound multichannel audio (5.1). It says in its back that the output impedance can be form 6 to 16 ohm for each speaker system.
    However, I already had the speakers system and 2 of them are of 4 ohms.
    My question:
    How can I convert from 4 to 8 ohms. Put a 4 ohms resistor in series?
    It works, but with some lost of power and quality.
    Put two speaker of 4 ohms in series will also not work
    because they do not fit in the speaker system.
    Is there another way to convert it from 4 to 8 ohms?
  2. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    I would personally be surprised if the amp can not drive a 4 Ohm load (regardless of the stamped rating), my advise don't sweat it too much unless you are running these things at maximum volume and pushing the limits, or experience a thermal shut down... If you are only running them at minimal volume levels I doubt you will experience any issues with the 4 Ohm load... The mix max of load will diminish performance but as you have found trying to force shift the load with a resistor will also have effects and diminish performance even more as well as being a waste...
    Putting another speaker in series is the better option, even if it's in a different enclosure...
    Best option is to get new speakers that match...
  3. CMarangon
    CMarangon
    14
    Feb 3, 2013
    Indeed, to try to find an 8 ohms speaker that matches is my first option.
    My 2nd option is to put a resistor in series.
    I also have a 3r option. In my city there is a man that refurbish speakers. Maybe he can convert it to 8 ohms, but for that he needs to have the repair kit, that is hard to find for this kind of speaker (8 ohms, 3 inches, 25 WRMS speaker)
    Thanks for your reply.
  4. davenn
    davenn Moderator
    13,802
    1,941
    you will just waste a lot of power in the resistor
    as CC said ... I would be suprised if your system couldnt drive 4 Ohm speakers without any hassles
  5. CMarangon
    CMarangon
    14
    Feb 3, 2013
    It says in its back part: SPEAKERS 6 to 16 ohms.
    Indeed, I am a little afraid to connect a 4 ohms speaker there.
    Thanks for reply.
  6. CocaCola
    CocaCola
    3,635
    5
    Apr 7, 2012
    We understand that, but based on an educated guess we suspect that 4 Ohms will be just fine... Most all audio circuitry and ICs made today will drive down to 2 or 4 Ohms without issue... The system as designed will likely work optimal with the specified 6 to 16 Ohm load but that doesn't necessarily mean it won't work with 4 Ohms... As I said unless you are pushing the system to the max, I highly doubt you will have any issues, using 4 Ohm speakers you will get more 'volume' at lower volume levels with the 4 Ohm speakers aka what you hear at volume setting 4 with 4 Ohm speakers is likely the same volume that you will hear at 5 or 6 with 8 Ohm speakers... This is why I suggest not pushing it to the limits with the lower Ohm speakers, you will get inferior sound and more distortion, something that won't happen with the 'proper stamped speaker ratings'...
