Convert CRT TV to Monitor
Discussion in 'General Electronics Discussion' started by JOSMAN, Aug 23, 2016.
  1. JOSMAN
    JOSMAN
    Aug 23, 2016
    My old GoldStar CRT TV only has an RF socket for antenna connection. I would like to know where to connect RCA AV (mono audio) sockets into the circuit board in order to use the set as a monitor for external AV sources. I presume that the outer contact of each AV socket would be soldered to the "ground" of the circuit board, leaving one other Audio connection and one other Video connection to be made. Any ideas? Thanks.
  2. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    The RF signals this TV uses to receive video are very different than the composit video signals used by (RCA AV) such as surveillance cameras. I dont know of a way to just solder an RCA plug on the circuit board and get picture and audio.
    One easy way to do what you want is to get a composit to RF video converter.
    something like that:
    http://www.ebay.com/itm/Universal-C...468919?hash=item1c1318ae77:g:M1UAAOxy--NRvN8z
  3. JOSMAN
    JOSMAN
    Aug 23, 2016
    Thanks for the suggestion. I was hoping to avoid converting AV to RF and then from RF back to AV as this causes loss of clarity. It would have been good to feed AV signal directly into the AV part of the TV set. Thanks again.
  4. HellasTechn
    HellasTechn
    1,557
    215
    Apr 14, 2013
    Understood but i have no idea if that is possible.
