Convert AND/OR logic circuit to NANDD-NAND logic circuit
Discussion in 'General Electronics Discussion' started by Researchers, Sep 22, 2017.
  1. Researchers
    Researchers
    5
    Sep 22, 2017
    The implementation of Boolean function using NAND-NAND logic requires the function must be in SOP . The following steps are followed to convert AND/OR logic circuit to NAND-NAND logic:
    Step-1: Check the given function is the simplified SOP expression or not. If not, then convert it into simplified SOP expression.
    Step-2: First draw logic circuit using AND/OR gate.
    Step-3: Add bubbles on the output of each AND gate and add bubble each input side of OR gate.
    Step-4: Replaced bubbled OR by NAND gate
  2. (*steve*)
    25,299
    2,737
    Did you forget NOR?
    And your rules will change the function of the circuit.
