convert 4.7 volt to 1.5 volt DC
Discussion in 'General Electronics Discussion' started by arul narayanan, Jan 17, 2011.
  1. arul narayanan
    arul narayanan
    Jan 17, 2011
    hi this is arul..
    I need to convert the output of a nokia mobile charger(4.7 volt) to 1.5 volt or less.
    is there any way to do this by simple components from household junk?
    i have some s8550, lm358, small coils lot of resistors , a UPS circuit board,LEDs.
  2. alfa88
    alfa88
    331
    4
    Dec 1, 2010
    The voltage drop across a silicon diode is in theory .7volts. 2 of them in series would be
    1.4 volts. I don't think a nokia charger puts out too much current so maybe try a couple rectifier diodes. 1N4001, 2, 3, etc. measure before you hook up your load.
  3. (*steve*)
    25,482
    2,830
    You could use a LM317 adjustable regulator which will allow you to set the output voltage as low as 1.25V. The input current is the same as the output current and the extra voltage (* current) is dissipated as heat.
