Convert 2 way switch/ splitter
Discussion in 'General Electronics Discussion' started by Gruntlife99, Feb 9, 2014.
  1. Gruntlife99
    Gruntlife99
    4
    Feb 9, 2014
    Is it possible to convert a 2-way switch into a splitter?
  2. davenn
    davenn Moderator
    13,947
    1,988
    hi there
    welcome to the forums :)
    tell us more about what you are trying to achieve
    with the little info you have given its really difficult to give a good answer
    cheers
  3. Gruntlife99
    Gruntlife99
    4
    Feb 9, 2014
    So I have 2 in 1 out hdmi switch and I need a 1 in 2 out splitter to use for xbox 360 on two tv's. Is there any way to reverse that switch to make it a splitter?
    Thanks Dave.
  4. davenn
    davenn Moderator
    13,947
    1,988
    just to confirm.... you want to feed both TV's at the same time ?
    that is ... see the same X-box pic on both TV's
    if so ... its probably a bit more involved that just paralleling up the wires
    it probably needs some sort of propper splitting and signal conditioning
    Im not too up to play on HDMI signalling, others may be able to give more info :)
    cheers
  5. Gruntlife99
    Gruntlife99
    4
    Feb 9, 2014
    I read a lot into and everything I can up with was doing the splitting but all I could find I stores around here was a switch box and so I thought before I order online if there was a way to reverse it.
    Thank you for replying though
  6. davenn
    davenn Moderator
    13,947
    1,988
    you didnt actually answer my question...
  7. Gruntlife99
    Gruntlife99
    4
    Feb 9, 2014
    Oh I'm sorry. Yes that is correct.. Two tv's, 1 xbox
