In said:
You would use less energy if you converted a chest freezer rather than an
upright. Everytime you open that door on your upright, all that cold air falls
out. If you have a chest freezer, you open the door and the air stays put. By
the way, this freezer conversion is used a lot by people living off the grid
and is better than a propane gas refrigerator
Also... make sure to use a "manual defrost" unit. An automatic one
will kick in some pretty power hungry heaters (the one on my
refrigerator/freezer pulls 400 watts) for some pre-defined time,
and that number is fixed at the factory. You might only ""need",
so to speak, 2 minutes of defrost every 48 hours, but it had
to be designe for the worst case scenario.
(It's only in the past few years that we've started to see
some intelligence/feedback on defrosters).
_____________________________________________________
Knowledge may be power, but communications is the key
[email protected]
[to foil spammers, my address has been double rot-13 encoded]
