Controlling things with the parallel port
Discussion in 'Electronic Basics' started by joel, Aug 21, 2003.
  1. joel
    joel Guest
    I have read a document on controlling led's with a parallel port. I
    plan on using the led's to make an optio isolator connected to a relay
    to control things around the house. first off, i was wondering if
    anyone knows of a book that covers things at a basic level like this
    and secondly a parallel port can only control 8 devices, is it cheaper
    to use multiple computers or is there perhaps some type of system out
    there that will let me control more?
    thanks for any input
  2. John Jardine
    John Jardine Guest
    You only need 1 computer.
    A method is to just use 3 of the port pins (eg D0-D1-D2), to -serially- send
    a set of on/off bits to one or more 74HC595 i.c.'s.
    Each 74HC595 chip can control 8 outputs. 4 chips (say) could control 32
    optos.
    For example,
    D0 serially puts out the opto-led, ON or OFF bits to the 74HC595's
    D1 makes a clock pulse for each of these serial opto-led bits.
    After all the data bits are sent out then D2 is set high then low, to tell
    the chips to latch the sent data onto their output pins.
    (Use optos that have low current LEDs to avoid loading the 74HC595 o/p pins)
    regards
    john
  3. the Wiz
    the Wiz Guest
    Check Jan Axelson's site www.lvr.com and her book on interfacing the parallel
    port.
    It's relatively easy from DOS and Windows 3.x, but you need additional interface
    software (drivers, etc) for Windows 95 and higher.
    You might also consider a separate controller board, such as the one from
    http://www.boondog.com/ (click on the Products link).
    More about me: http://thelabwiz.home.mindspring.com/
    VB3 source code: http://thelabwiz.home.mindspring.com/vbsource.html
    VB6 source code: http://thelabwiz.home.mindspring.com/vb6source.html
    VB6 - MySQL how to: http://thelabwiz.home.mindspring.com/mysql.html
    My newest language - NSBasic for the Palm PDA: http://thelabwiz.home.mindspring.com/nsbsource.html
    Drivers for Pablo graphics tablet and JamCam cameras: http://home.earthlink.net/~mwbt/
    johnecarter atat mindspring dotdot com. Fix the obvious to reply by email.
  4. cpemma
    cpemma Guest
    The method John outlines has a circuit at DiscoLitez:
    http://discolitez.com/download.shtml and there's the software too.
  5. Si Ballenger
    Si Ballenger Guest
    I've got the below page showing how to use the parallel port to
    control my homemade webcam video switchers using "notepad"
    software. The "El Cheapo #3" setup could control ~40 things one
    at a time, and is made totally from Radio Shack parts. If you
    really want to be a parallel port control freak, the bottom link
    shows how to individually control up to 380 strings of christmas
    lights via the parallel port.
    http://www.geocities.com/zoomkat/ppswitcher.htm
    http://tinyurl.com/ksbc
  6. Bob Masta
    Bob Masta Guest
    The parallel "port" includes 3 separate I/O ports: Data, Status, and
    Control. To control more than 8 bits, you can use the Control port
    to provide 3 additional bits directly (it's got special uses for some
    bits). For lots more outputs use those 3 extra bits as address bits
    to select one of 8 octal latches that are updated by the Data port.
    Bob Masta
    dqatechATdaqartaDOTcom
    D A Q A R T A
    Data AcQuisition And Real-Time Analysis
    Shareware from Interstellar Research
    www.daqarta.com
  7.
