Controlling LED Piranha with PWM controllers
aquarius
Oct 26, 2009
Oct 26, 2009
In my project I need to control intensity of 8 LED Piranha by using following components(see an attached file):
- LED RGB Controller ( simply changes combination of R,G,B colors)
- OPTO22 ODC15 Solid state relays module
- 8 independent PWM controllers (work from software and change output voltage from 0 to 12VDC)
- 8 LED RGB Piranha 12VDC, 25mA, with resistors
My point is to make dimmable 8 LED Piranha while the LED Controller changes colors. Each LED performs according to the PWM Controller output voltage.
I've already made and tested only one LED. Works perfect.
Don't know where to connect other 7 negative outputs from PWM's.
Do I have to have 7 more OPTO22 or there is another solution?
Need help.
Thank you.
aquarius
Oct 26, 2009
Oct 26, 2009
I did this and it doesn't work. All PWM Controllers don't change output voltage, while they get input signal from 0 to 10V. Only ONE controller works, in case of diagram presented.
