well i am doing a project on controlling 2 stepper motots along x and y
axis.which is the best way to do so.using 8051 or x86 or any other
way...
A few questions:
* Have you given consideration to maximum stepping speed?
* Are you doing microstepping?
* Is your processor going to be involved in current control of phases?
* What are you doing for a motion profile? Straight-line, trapezoidal,
* Is this a free-standing controller that performs one task over and
over? Or is this a stepper indexer/controller that accepts commands
from another source (DIP switches, another computer)?
* If this is a general indexer, what additional commands shall your
controller do?
* Are you making any provision for home, nearly home, or any other
positioning signals on one or both axes?
* Do you know what's being asked in the above questions? (If not, you
might start by reading Jones on Stepping Motors:
http://www.cs.uiowa.edu/~jones/step/ )
This is only scratching the surface of the things you're going to have
to decide. And as you should know, the processor choice is determined
by the project requirements.
On the other hand, I've seen a lot of 8052-based stepper stuff. I've
also seen one or two 80186-based stepper controllers. I would guess
one axis is very doable with an 8052. Two axes, possibly you might
want to go with one of the newer 8052 derivatives, which have higher
clock speed, fewer clock cycles per instruction, and more hardware
timers (you can never have enough).
Actually, if you look around, you'll probably find a number of
free-standing stepper controllers based on any number of processors.
This should give you some idea of what kind of features you could
provide in your project.
Oh, yes. This is a school project, of course. Is this a trade school
or university project, and is this the senior project? And, sadly,
when is it due?
Chris
