Controlling 12V from 5V
Discussion in 'Electronic Basics' started by Buddy Smith, Jun 29, 2005.
  1. Buddy Smith
    Buddy Smith Guest
    Newbie question......
    I have a device I'm trying to turn on/off that requires 12V. I want
    to control it with a micro that runs at 5V.
    My question is can this be done with a power MOSFET, or do I need a
    relay?
    Assume that the current running through the controlled device is not
    much, but it will be on mostly 24/7. It will be turned off several
    times a day for say 5 seconds or so.
    ttyl,
    --buddy
  2. Byron A Jeff
    Byron A Jeff Guest
    Fire away.
    How about a simple NPN transistor? power MOSFETs generally require a gate
    voltage that exceeds the drain, which will be at 12V.
    You can use an NPN power transistor as long as the current requirements of
    your device doesn't exceed the current the micro I/O pin can supply. The
    hfe for a 2N3055 ranges from 20 to 70 for example. So an I/O pin that can
    supply 20ma to the base and control a load between 400ma and 1.4A.
    You could use a darlington arrangement if you need to drive a larger load.
    Finally if you used a relay, you would still need a transistor relay driver
    to drive the relay.
    How much?
    Now a relay could be useful here because you could run the circuit through
    the normally closed contacts. No power would be consumed the majority of
    the time. Activating the relay would turn the device off.
    BAJ
  3. John Fields
    John Fields Guest
    If you can switch the low side of your load you can use a logic-level
    MOSFET, like this:
    +12
    [RL]
    D
    ON>-------G NCH
    S
    GND
    If you have to switch the high side, you could use a P-channel mosfet
    driven by an NPN bipolar, like this:
    +12>----------+----------+
    [R2] |
    | S
    +--------G PCH
    | D
    C |
    ON>---[R1---B NPN [RL]
    E |
    GND>----------+----------+
  4. Buddy Smith
    Buddy Smith Guest
    This was my first thought when the MOSFET didn't work as i'd hoped.
    The application is a magnetic door lock. It pulls about 208-210 mA at
    12V.
    I have a couple of NPN and PNP MOSFETs laying around and can get
    anything I need.
    --buddy
  5. John Fields
    John Fields Guest
  6. Buddy Smith
    Buddy Smith Guest
    err Power MOSFETs I mean :)
    I have TIP120s.
    I'm really glad i'm not posting this with my IEEE email address...I'd
    get banned for life :)
    --buddy
  7. Byron A Jeff
    Byron A Jeff Guest
    Absolutely. Collapsing magnetic fields cause really bad spikes if undamped.
    N-channel and P-channel. But you needed to pay attention to the fact that
    John said "logic level" MOSFETs. With ordinary MOSFETS you have to get
    the gate voltage well above (or below) the drain.
    Those will work. They are not MOSFETs however. A quick look at the datasheet
    indicates that they have high gain (hfe of 1000 typical). So at 10 ma of
    base current they can drive 5A easily. So the 200 mA of your solenoid should
    be absolutely no problem.
    BAJ
  8. Buddy Smith
    Buddy Smith Guest
    Hm. The maglock I have is packaged with a small circuit board. I haven't
    pulled it out (it's glued down) but it includes a +24V connector, a +12V
    connector, and GND. There is a large resistor and a normal size disk
    capacitor on the board. I figured out that the resistance of the coil
    is ~ the resistance of the large resistor, so that's just a voltage
    divider.
    So, what's the best way to power this on and off with my TIP120? Or is
    there something I should pick up that will work better? Honestly I used
    these because I had them laying around and was anxious for a prototype.
    Fear not, good sirs, this is not a production unit :)
    Actually it's not a solenoid. Just a big electromagnet.
    Do I need to add a diode somewhere to make this a little safer/etc?
    Thanks for the advice.
    --buddy
  9. ehsjr
    ehsjr Guest
    Err - the absolute maximum continuous current is 5A, so
    "easily" doesn't apply. To get the absolute maximum
    continuous current of 5A (or pulse current of 8A), you
    need to drive the thing with 20 mA of base current.
  10. ehsjr
    ehsjr Guest
    The diagram below assumes that your door lock is
    wired such that the +12V is switched. Also, it
    is designed so that you don't have to break
    the existing doorlock wiring - just tap into it at
    one point.
    +-----DoorLock-------Gnd
    +-------|<--------+--Gnd
    | D1 1N4002 |
    | \ R2
    | / 10K
    e \ R1 |
    Q1 |----/\/\/\-----+
    TIP120 c / 470 |
    +12------------+ |
    +5 from micro--------------------+
    If your micro can source > 25 mA, change R1 to 220 ohms.
    Ed
  11. Ban
    Ban Guest
    But the TIP120 is an NPN transistor, which will need almost +14V on the base
    to switch on +12V. Maybe you can use a TIP125, but with the emitter at
    +12V_in, or you switch with the TIP120 in the gnd-leg of that solenoid,
    which would be easier.
  12. ehsjr
    ehsjr Guest
    Errrp! I managed to screw that up, royally.
    A large part (inverter & converter) is missing from
    the first diagram, and the second diagram isn't there
    at all. Hopefully, I'll get it right this time:
    one point.
    | D1 1N4002 |
    | \ R2
    | / 10K
    e \ R1 |
    Q1 |-----/\/\/-----+
    TIP120 c / 470 |
    | Q2 2N3906 |
    +12------------+-----e c-----+
    | \___/
    | R3 | R4 Q3 2N3904
    +--/\/\/-+---/\/\/--c e------+-Gnd
    10K 470 \___/ |
    R5 | R6 |
    +5 from micro----------/\/\/----------+--/\/\/--+
    3.3K 33K
    wired such that the Gnd is switched.
    +-----DoorLock-------+12
    +------->|--------+--+12
    | D1 1N4002 |
    | \ R2
    | / 10K
    c \ R1 |
    TIP120 e / 470 |
    Gnd------------+ |
    Ed
  13. ehsjr
    ehsjr Guest
    Hi Ban,
    The TIP120 will turn on *way* lower than that. The emitter
    is not at +12 - there's about 60 ohms between it and ground,
    through the door lock. So you need only about two diode
    drops to get it to start conducting.
    But see the correction I was posting even as you were
    posting your question. I totally mangled the original
    diagram. I cut-and-pasted myself into oblivion when
    I drew it, and ended up leaving out most of it.
    I hate it when that happens! :,;
    Ed
    Ed
  14. Bob Monsen
    Bob Monsen Guest
    You say the board has both 12 and 24 volt power supplies. If you are
    only using the 12V power supply, then you can just switch on and off the
    ground with your TIP120. Connect the ground of the card to the collector
    of the TIP. Connect the emitter of the TIP to the real ground. Now,
    connect the base to your microcontroller using a 1k resistor.
    (This is what Fields meant when he said 'low side switching'.)
    When you make the port high, it'll turn on the TIP120, which should
    completely saturate, thus not dissipating too much power (it won't get hot.)
    When you make the port low, it'll turn off the TIP120, which will allow
    your load to float up to 12V, which isn't a problem.
    If you are supplying both 12 and 24 volts, though, it's possible that
    there may be current flow between these two rails, so I'd only do this
    if you are using one or the other. Or, you could use a diode into the
    12V rail, which would prevent reverse current flow.
    If the board has a coil on it, connect a 1N4001 from the point where the
    collector attaches to the ground on the board, to the 12V rail. Then,
    the current generated by the inductor will just circulate through the
    diode until it dissipates, rather than generating a huge voltage spike
    which could kill the TIP120. The TIP120 can only withstand about 60V
    between collector and emitter.
    Regards,
    Bob Monsen
    If a little knowledge is dangerous, where is the man who has
    so much as to be out of danger?
    Thomas Henry Huxley, 1877
