R
Robert Monsen
Ok, I've got a simple scheme for controlling these using an 'unnamed 5V
device'
The problem is that I need to be able to switch the 10V common anode, and
ground the a-g inputs, all using 5V outputs from a shift register. An open
collector buffer like a 7407 works for the latter.
http://home.comcast.net/~rcmonsen/steve/steve.html
Page down to the second section. It shows a schematic for powering the
common anode using two transistors and three resistors.
However, this is a pretty common thing to want to do. I'm guessing there is
an IC that can do it for me without the added transistors/resistors. I spent
a few moments in the philips device tree looking for something, but didn't
find anything that would work.
I looked at analog switches, but their 'on' voltage is about 7V for a Vcc of
10V.
I looked at CMOS buffers, but they have the same problem.
Is there a part that is cheaper than the 6 times (two transistors/3
resistors/extra solder and wire runs)?
(Of course, the other way is simply to drive each 7 segment from its own
shift register. However, that means 6 shift registers, and 8 open collector
buffers, and their wire runs)
Bob Monsen
device'
10V.
Bob Monsen
