controling the heater
Discussion in 'General Electronics Discussion' started by nel, Sep 3, 2013.
  1. nel
    nel
    10
    Jun 24, 2013
    hi my name is nick.... Can i control the 5000w heater wen i use potentiomerter?
    What should i do? Pls help me .thanks.....:)
  2. Harald Kapp
    9,500
    1,957
    No potentiometer will control a 5000W device.
    You will need a controler rated for 5000W. A kind of Dimmer could work, although it will create a lot of noise on the mains power. Since a heater is usually rather slow in heating up and cooling down, a simple two-position controller will be better suited.
    Your question is evidence of a certain lack of understanding of electronics. I strongly recommend you do not attempt to build such a controller on your own. Buy a commercial controller or at the very least get the help of someone experienced in that kind of circuit. This is dangerous!
