Control Yamaha HTR-5660 with Raspberry Pi
Discussion in 'Audio' started by kdei, Jun 15, 2020.
  1. kdei
    kdei
    Jun 15, 2020
    Hi I have a Yamaha HTR-5660 in working condition.
    The only thing is that it is not network-ready. I'm well versed in Raspberry Pi but less familiar with electronics. I wanted to see how I can control at least on/off, volume, and input selector via the network.
    Yamaha publishes these nice repair manual which I can use as a starting point but don't know where to start.
    Any pointers on what components I should begin looking at?
    Thanks.
  2. Harald Kapp
    10,025
    2,138
    Have a link for us?
  3. kdei
    kdei
    Jun 15, 2020
  4. Audioguru
    Audioguru
    2,832
    634
    Sep 24, 2016
    The old audio receiver is controlled with switches and knobs to be used by your hands. Why control it over a network?
    My Yamaha audio receiver is a little older than yours and its switches have worn out so it does not work anymore.
  5. Harald Kapp
    10,025
    2,138
    Let's for starters have a look at e.g. the input selector:
    Input selection is done by a 74HC4051 analog multiplexer. Control inputs are VIA, VIB, VIC (pins 9, 10,11). To allow electronic remote control of this input selector you will have to cut the present connections to these 3 pins and connect the inputs to the outputs of e.g. a raspberry pi. You can then select an input by setting the appropriate pattern on the output of the raspi.
    Volume is adjusted by another type of IC: YAC520
    This chip is controlled by a serial interface. While you may be able to detach the pins of this interface, connect the interface to a raspi and control the chip using your own serial commands, this will not be as simple as the change to the input selector. But not impossible.
    There is a risk, however, that the controller of the AV receiver will shut down the receiver if it can no longer establish communication with these chips.
