Continuous rotary switch
Discussion in 'Electronic Design' started by [email protected], Feb 4, 2008.
  1. Guest
    Hello all,
    What's the name for one of those knobs like you get on radio's for
    volume controls where it keeps turning and there's no stops? And how
    does it know which direction the knob was turned?
    gareth
  2. Joerg
    Joerg Guest
    Rotary encoders. Many methods, for example two offset optical disks.
  3. On Mon, 4 Feb 2008 14:25:37 -0800 (PST), in sci.electronics.design
    Shaft encoder, also maybe gray code, do a wiki search
    martin
  4. Try "rotary encoder".
    Specifically a quadrature rotary encoder. They have two outputs that
    each generate N pulses per revolution (N being determined by the
    resolution or sensitivity you desire). The two outputs are 90 degrees
    out of phase, so as the knob is spun, software can determine which
    direction it is spun by the phase relationship of the signals.
    See http://en.wikipedia.org/wiki/Rotary_encoder
  5. Marra
    Marra Guest
    Its a rotary encoder.
    You just count phased pulses from it.
    You can tell the direction from the phase the 2 pulses move.
  6. whit3rd
    whit3rd Guest
    For a really good picture, saw open a moving-ball mouse
    (pick one you never liked...). There's two in there,
    one for each of the (X and Y) axes.
