Constant voltage increment circuit
Discussion in 'General Electronics Discussion' started by Yogesh Baj, Sep 25, 2017.
  1. Yogesh Baj
    Yogesh Baj
    6
    Sep 25, 2017
    I am a civil engineer and hence dont know anything about electronics so please help me. I need a circuit or a device which increases voltage for -250mv to +250mv at a rate of 0.1 mv/second
  2. AnalogKid
    AnalogKid
    2,476
    714
    Jun 10, 2015
    We need more details about your question.
    Are you talking about a circuit that takes in input voltage of -250 mV and translates it to an output voltage of +250 mV?
    Are you talking about a circuit that produces a voltage ramp from -250 mV to +250 mV?
    Something else?
    If the circuit has an external input, what is that input coming from? A sensor of some type, another circuit, etc?
    What does the output of the circuit do? Does it drive a motor controller, an alarm system, etc?
    ak
  3. BobK
    7,682
    1,688
    "increases voltage ... at a rate of...." sounds like a description of a ramp to me.
    My questions would be:
    What starts the ramp?
    What does it do after it hits the max?
    What is the load on the output?
  4. Yogesh Baj
    Yogesh Baj
    6
    Sep 25, 2017
    input voltage can be any constant power supply source but the output voltage should be a increasing voltage at the rate of 1mv/sec starting from -250mV and ending at 250mV.
  5. davenn
    davenn Moderator
    13,793
    1,938
    1mV / sec or 0.1mV / sec as in your first post ?
    and what answers to the other questions you were asked ?
    the more you help us, the easier it is for us to help you
  6. Yogesh Baj
    Yogesh Baj
    6
    Sep 25, 2017
    0.1mV/sec would best but is this is not possible then 1mV/sec can also work.
    Actually there are three electrodes in a conductive liquid I have to apply a voltage which increases at rate of 1mV/sec or 0.1mV/Sec (which ever possible) between 1 and 2 electrode and measure current between electrodes 2 and 3 every second. After it hits the maximum voltage the i will change one of the electrodes with another sample and repeat the same process . And so on with different samples. And by getting the voltage and current readings I have to plot certain graphs and do further calculations for my project. I have a device that can measure current so I just need a voltage source which increases as per my requirement mentioned above.
  7. Yogesh Baj
    Yogesh Baj
    6
    Sep 25, 2017
  8. Yogesh Baj
    Yogesh Baj
    6
    Sep 25, 2017
    I don't understand what ramp is
    After hitting max it should reset and carry out the same process but with different sample
  9. AnalogKid
    AnalogKid
    2,476
    714
    Jun 10, 2015
    Sounds like a potentiostat.
    What starts the ramp? Press a button? A computer signal?
    After one ramp. does the output sit at +0.250 V, return to 0 V, or what?
    ak
  10. Yogesh Baj
    Yogesh Baj
    6
    Sep 25, 2017
    A button and after one ramp is complete at +0.250 V it returns to -0.250 V then I connect a different sample and the ramp starts again from -0.250 V after pressing the button
  11. davenn
    davenn Moderator
    13,793
    1,938
    and what tells it to start the ramp again ?
    you will need a control process in there .... a microcontroller etc
