Connector
Discussion in 'Electronic Components' started by Brett Foster, Aug 27, 2003.
  1. Brett Foster
    Brett Foster Guest
  2. Boris Mohar
    Boris Mohar Guest
    Are you sure that you did not mean cm instead of mm? Can you take a
    picture and pos it to alt.binaries.schematics.electronic
    Regards,
    Boris Mohar
    Got Knock? - see:
    Viatrack Printed Circuit Designs http://www3.sympatico.ca/borism/
    Aurora, Ontario
  3. Brett Foster
    Brett Foster Guest
    My news server doesn't have the binary groups... Still I am sure those
    are mm since it's a very small connector. It's on a pentax camera, and
    is used to provide 4.5Vdc obtaining the power supply is both costly and
    hard to get. Since I have all the equipment, and since it will be used
    in a custom way, it would be nice to find the real connector.
  4. Cyrus
    Cyrus Guest
  5. CWatters
    CWatters Guest
    Less than 1mm pitch between the two contacts! Sure you have those dimensions
    right?
  6. Brett Foster
    Brett Foster Guest
    Oh god. Now I've figured it out. The other poster was right when that
    should have been CM.
