Hi and thanks in advance for advice.
I have a set of LED fairy lights which have a 2 pin speaker DIN connection at the end - which should plug into an AC 6V power adaptor (the power adaptor has a socket for the DIN connection). However the power adaptor is broken and I am having real trouble tracking down a replacement. So - is there any way I can convert the DIN connection to something more commonly found? Or would it be possible to cut the DIN off and replace it with a conventional jack? Would this be difficult to do?
Thank you!
Thank you!
