Connecting non-solderable wires
HANKMARS
Jul 28, 2019
498
Jul 28, 2019
498
I will be using resistance wire which will not accept lead/tin solder. On prototype I would use a loop to loop sort of configuration when one of the wires were solder-able. This would tightly trap the resistance wire but is unsuitable for practical use. I desire to have a positive hold at these connections. How have you seen these connections made up resulting in secure, rugged results?
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
I used to use chromel/alumel thermocouples, there could not be soldered with tin/lead solder so the ends were 'tinned' with silver solder (Easyflow) which would take normal solder very well.
Bluejets
Oct 5, 2014
6,892
Oct 5, 2014
6,892
Thermocouples are supposed to use dedicated material type terminations to suit the thermocouple type otherwise the readings will be off.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
There will be temperature errors if the junction is not at a uniform temperature. We used compensation cable (copper/constantan?) to extend the couple by several meters and this worked well. The cold junction was at the measuring meter/computer.
The main problem was making a neat thermocouple junction. This was done with a gas/oxygen flame. I became quite good at this and could make a junction no wider than the two wires side by side so any hole would be small and not have a great effect on the thermal flow.
HANKMARS
Jul 28, 2019
498
Jul 28, 2019
498
Very nice solution but does not fit this application. Thank you for your response.
HANKMARS
Jul 28, 2019
498
Jul 28, 2019
498
This may very well be the best solution. I assume Easyflow silver solder will have a somewhat higher melting point. Or I can make a silver solution and deposit the silver on the wire by electrolysis. The wire is KANTHAL A-1 FeCrAl alloy. Ferrictic iron-chromium-aluminium alloy. For use up to 2550º F (1400º C). A bit of overkill seeings how I do not wish to exceed 115º F. I will try to post the heat shrinkable connectors that I have purchased.
HANKMARS
Jul 28, 2019
498
Jul 28, 2019
498
Crimp link.
I considered crimp links and would fill voids with tin/lead solder but am concerned with wire pulling out. A loop to loop primary connection with a crimp connector filled with solder might keep joint from failing completely but may also result in sporadic conduction.
Ylli
Jun 19, 2018
401
Jun 19, 2018
401
A properly sized crimp will make an airtight and secure connection. No 'solder fill' required.
HANKMARS
Jul 28, 2019
498
Jul 28, 2019
498
OK. These are solid wires, not stranded, but still quite possible I imagine.
HANKMARS
Jul 28, 2019
498
Jul 28, 2019
498
Ylli
Jun 19, 2018
401
Jun 19, 2018
401
I thought you said the resistance wire was not solderable. These form the connection via soldering.
HANKMARS
Jul 28, 2019
498
Jul 28, 2019
498
Yes they do. My initial thot was that the mere "snugness" of the connector would be enough to maintain acceptable electrical conductivity. Another reader mentioned silver solder tinning. I will be trying that suggestion soon. The reader mentioned that the silver tinned wire readily accepted tin/lead solder, which does sound correct. And if that all rings true, I will have solved this problem of mine with the help of active readers. Thank you all for your participation. I will let you know the outcome.
duke37
Jan 9, 2011
5,364
Jan 9, 2011
5,364
If the resistance wire gets hot, then tin/lead solder would probably fail. Electric elements are often spot welded. You could use Easyflow for the entire connection.
HANKMARS
Jul 28, 2019
498
Jul 28, 2019
498
Hopefully, maximum temp will be 115º F. Will I be able to use Easyflow with soldering iron? My cheapo adjustable iron adjustment knob implies that it can reach 450º F.
Bluejets
Oct 5, 2014
6,892
Oct 5, 2014
6,892
I can foresee this ending in a complete mess.
Just use a crimplink or a ceramic terminal block and be done with it.
