Connecting a computer to the screen on my home theater system
Discussion in 'Beginner Electronics' started by Bradley Burton, Jan 11, 2006.
  1. This is complicated, and I'm not sure if anyone can actually solve this, but
    I thought I would ask. I will try to explain this as best I can.
    I looked up how to hook up a computer to a TV online, and it basically says
    that the way to do this is to connect the cord from the video card in my
    computer to the video input (the yellow socket) on the TV, then switch it to
    aux mode.
    I'm having problems sending my computer image to my screen because I'm using
    a projector, so I don't have a TV where I could just plug in the video cord
    from the computer to the TV.
    My AV receiver has tons of sockets (not sure if that's the right word) in
    the back, however in the front, just like a TV, it has, for Aux 1 input, a
    video, L, and R sockets. I plugged the cord into the video socket, turned
    on the system, and switched the receiver to aux 1 mode.
    The computer picture is not showing up. Instead of the computer picture
    showing up, the TV picture shows up (with no sound).
    I have a cable box where the TV picture is coming from. It also has Video,
    R, and L sockets too. Plugging the video cable into that also doesn't work.
    Should I be focusing on the AV receiver or the cable box?
    Also, I'm not sure if this part matters or not, but the projector itself has
    8 different input options. I've plugged in the cord into the receiver,
    turned it to aux mode, and tried all 8 options, and I still don't get what I
    want. Should I be focusing on this too?
    Any help would be appreciated.
    Thanks, Brad
  2. DaemonWalker
    DaemonWalker Guest
    What Brand and Model of Projector are you using and the same for the
    Receiver?
  3. The projector doesn't have a connector like that, but it does have a yellow
    video socket. When i pull out the cord in the video socket of my projector
    for some reason the projector still projects the video. It's like pulling
    it out doesn't do anything. Pulling it out and putting in the video
    connector from my computer doesn't work.
    Brad
  4. The projector brand is an InFocus 7205, and the receiver is a Marantz
    SR7500.
    Brad
  5. Ok. I do see those connectors on the projector. Do you know where I might
    be able to find a cord that has an S-Video connector on one side (for my
    video card) and a VGA or M1-DA connector on the other side? I tryed calling
    RadioShack and CompUSA and they both said that they didn't have a cord like
    that.
    Brad
  6. quietguy
    quietguy Guest
    I guess you know something I don't, because for my first computer back in '81
    or so I used a cheapo TV as my monitor. Just broke into the video circuit, and
    fed the output from from my Exidy Sorcerer into it.
    Used it to write basic programs, kids played games, wrote a (very simple) word
    processor for it in assembler, and although I never was able to afford to buy a
    proper computer monitor it served me to write all my uni assignments for a
    couple of years.
    But having been out of the TV game for some time now, I guess things have
    changed and the defn isn;t as good now as it was then - or ???
    David
