M
[email protected]
Homer said:Hi All,
I am planning to remove the light fixture from one of our rooms and put
200 LEDs instead. LEDs are going to be:
Reverse Voltage:5.0 V
DC Forward Voltage: Typical: 3.4 V Max: 3.8V
DC Forward Current:20mA
How can I connect them all to a AC outlet (110V or 120V? in Canada).
I believe I need to put a "bridge rectifier" to prevent blinking and
they should be mixture of parallel and series.
Thanks if advance,
Homer
I see no current regulation in your design.
Looking at failed commercial LED arrays in traffic lights, I gather
they do a combination of serial and parallel. If I were to build one,
I'd do strings of LEDs that are current regulated. While you can get
effectively brighter output by pulsing LEDs, I'd rather have DC. [Less
RF noise.]
Dig up a 48V power supply. Current regulation can be done with an
opamp, voltage regulator, and NPN BJTs. [NPN E to resistor. Resistor to
ground. Intersection to op amp negative input. Op amp positive input to
reference. Assume BJT matching is close enough that only one have to be
in feedback loop. ] LED string to plus rail of supply. Other end to C
of NPN.
