connecing a PICkit 2 => PIC24EP128GP
foTONICS
Sep 30, 2011
332
Sep 30, 2011
332
Looking up the schematic for the PICkit 2 I have:
pin 1: Vpp/MCLR
pin 2: Vdd Target
pin 3: Vss (ground)
pin 4: ISCPDAT/PGD
pin 5: ISCPCLK/PGC
pin 6: AUXILIARY
and looking at the datasheet for the PIC24 I have the corresponding pins:
pin 1: MCLR
pin 13: Vdd
pin 19: Vss
the next two pins is where I'm sorta confused. I noticed there are multiple sets of PGEC/PGED options. Does it matter which one I use or can I just do this?:
pin 7: PGD
pin 6: PGC
Am I correct in thinking that PGEC = PGC and PGED = PGD?
7,682
7,682
You can use any of the PGC PGD pairs for programming. You can then set configuration bits to determine which pair is used for debugging.
