Confused with a contactor
Discussion in 'Troubleshooting and Repair' started by Dakota Keel, Jan 22, 2016.
  1. Dakota Keel
    Dakota Keel
    3
    Jan 22, 2016
    I have a 30qt mixer I'm trying to fix, and under the cover it has a Allen Bradley 100-C16 contactor that is hooked up very strangely to a Z-BW06 switch (also hooked up strange) as well as a ZB2-BE102 and an AT-615C timer.
    I see some very obvious problems looking at it but I have a time line to get this fixed and I would really appreciate some support.
    (I've looked online with no luck finding a wiring diagram for this thing, and I don't know enough about wiring to trust myself to NOT fry the $100 contactor)
  2. Minder
    Minder
    3,120
    673
    Apr 24, 2015
    I get message saying not authorized to view attachments for some reason??
    M.
  3. Ian
    Ian Administrator
    1,487
    435
    Aug 23, 2006
    Thanks for the heads up - I couldn't view them properly either (not sure what happened), so I edited the post to manually add them. I'm looking at the logs to see what happened :).
  4. Minder
    Minder
    3,120
    673
    Apr 24, 2015
  5. Dakota Keel
    Dakota Keel
    3
    Jan 22, 2016
    Thank you for fixing the images for me
  6. Dakota Keel
    Dakota Keel
    3
    Jan 22, 2016
    If you could just confirm whether or not that little grey board on top is just passing power directly through it I will draw up a diagram of how it is currently wired
  7. Minder
    Minder
    3,120
    673
    Apr 24, 2015
    It appears to me as just a 12 row terminal strip.
    Continuity test would confirm it.
    M.
  8. hevans1944
    hevans1944 Hop - AC8NS
    4,626
    2,159
    Jun 21, 2012
    It appears to be a "special" terminal strip. Some of the adjacent terminals appear to be internally connected together: R and T; T and R; 6 and 5 reading from the top down. Note the placement of the test prod holes. Power it down (un-plug the line cord) and check continuity to be sure.
    It sounds like you may be unqualified to work on this equipment.
Similar Threads
Loading...
