Confused about transformer windings
Discussion in 'General Electronics Discussion' started by hrishib, Oct 27, 2013.
  1. hrishib
    hrishib
    34
    Aug 30, 2013
    I have a toroidal transformer which has two 115V primaries and two secondaries rated at 25VA each (2x18V each capable of delivering 1.389A). I've attached the datasheet here. I'm a bit confused about using this with 230VAC primary voltage. Can I connect the two primaries in series (blue+green connected, 230V mains AC between Brown and Violet) to get 230VAC and the two secondaries in parallel (Red+Yellow and Black+Orange) to get 18V at 2.778A? Color codes are specific to this datasheet.
  2. duke37
    duke37
    5,364
    769
    Jan 9, 2011
    Connecting the primary windings in series should be OK but they MUST be connected correctly.
    The secondaries can be connected in parallel if the transformer has been made to have identical voltages. If the voltages are not identical then one winding will feed power into the other. They MUST be connected correctly.
  3. hrishib
    hrishib
    34
    Aug 30, 2013
    Thanks Duke. Yes they have identical voltages on both the primary and secondary sides. Are the connections that I've suggested the right way to do it?
  4. KrisBlueNZ
    8,393
    1,270
    Nov 28, 2011
    Yes, your colours are right.
