Conductive Carbon paint
Discussion in 'Electronic Repair' started by Jefferson O. Siy, Sep 5, 2003.
  1. Any ideas on how to repair those worn out remote controls? The carbon
    under those rubber keys are just too thin. Maybe there's a way of
    recoating those rubber surfaces. Any ideas?
    Jeff
  2. C Yeung
    C Yeung Guest
    Check http://www.jameco.com
    The part number is 195186 and it costs 19.95.
    Best regards!
    Cliff.
  3. Bill Bolle
    Bill Bolle Guest
    Rub on some "dry powdered graphite" available in tubes from your local
    hardware store.
    Bill
  4. john
    john Guest
    Dont use ...........
    "dry powdered graphite:
    kpi
  5. Bill Bolle
    Bill Bolle Guest
    Why not? I've used that on my remotes and they have lasted longer
    then they did with the original coatings. Don't give a negative reply
    unless you are willing to include your reasons.
    Bill
  6. Bill Bolle
    Bill Bolle Guest
    Try the powdered graphite------it works!
    Bill
  7. Bill Bolle
    Bill Bolle Guest
    I apply the graphite by making a small pile of it on a piece of paper,
    sticking the end of a wooden matchstick in it and picking up only
    the amount that sticks to the end of the matchstick. I then rub this
    on the rubber pad until the pad looks shiny. After all pads are
    coated I shake and tap the pad assembly to assure all the loose
    graphite is removed and it's good to go. So far I have no incidence of
    loose graphite floating around in the the remote. This is similar to
    coating the pad with a #2 pencil but I think the pencil lead has some
    sort of filler in it that doesn't make it a good conductor. You can
    spend $20 to fix one remote or spend $3 and fix a thousand of them.
    Bill
  8. You can buy a new remote for less than $10 at Walmart, K-mart or any
    number of other discount stores.
  9. mike
    mike Guest
    Sure you can, but if it doesn't have the buttons required to operate
    your particular device, you've got a problem.
    Lemmesee...special-1-2-3-enter...I don't think so.
    If you've got a remote with buttons the same size, sometimes you can
    swap the bad button with a less-used function button.
    mike
    laptops and parts Test Equipment
    4in/400Wout ham linear amp.
    Honda CB-125S
    400cc Dirt Bike 2003 miles $550
    Police Scanner, Color LCD overhead projector
    Tek 2465 $800, ham radio, 30pS pulser
  10. Andre
    Andre Guest
    Been there, done that :) Worked fine .
    -A
