Conditioner power estimation
K
kunt
Hi all,
how many watts of conditioner power are needed to dissipate the heat of
1 watt of electrical equipment, keeping the conditioned room 8 degrees
celsius (46 Fahrenheit) below the temperature of the external environment?
Suppose small room and thermically insulated.
....we have a server room with 14KW of computers...
Yes we will call an expert for this estimation but please give me a
rough guess in the meanwhile.
Are there any formulas on the Internet for this estimation, which I can
study myself?
Thank you
S
Samuel Chan
My understanding is different electrical equipment will have different heat
dissipate, some equipment's catalogue will provide this info. CIBSE guide
books provide these heat info on general area.
Based on this heat dissipate info, the HVAC side can calculate the cooling
load and select the AC unit.
K
kunt
1kw of electrical ......
...A lot will bepend on ambient outside air temp ans sun load for that.
Yes please tell me how to keep into account the fact that we want to
keep the room at least 8 celsius (46 fahrenheit) below the temperature
of the outside air.
Thank you
K
kunt
of the outside air.
more precisely: max 32 Celsius when outside is 40 Celsius
| of the outside air.
When calculating _differences_ in temperature, conversion between celsius
and fahrenheit is slightly different. For every 5 degrees of difference
in celsius, there is 9 degrees of difference in fahrenheit. So if you
want the temperature to be 8 C less than outside, it will be 14.4 F less
than outside (not 46).
You have to know the rate that heat will flow into the room from outside.
This depends on so many factors that you pretty much just have to test it
and see. It's hard to test this with everything running, which you most
likely must do. One reason is the test varies depending on what the
outside temperature is.
Do the existing A/C systems run continuously or do they cycle on and off
in a normal manner? Is the temperature stable now, or does it go up and
down rather extreme? Is it just too hot in there and the A/C you have now
just can't cool it any better?
K
kunt
| of the outside air.
OF COURSE! Stupid me!
I used the google calc conversion, I didn't pay attention to the fact
that the C/F conversion it is not like all other conversions because of
the zero problem
Is this the only problem with the 8 degrees difference?
I thought that the biggest problem was the conditioning system working
less efficiently if they have to draw heat from a room which is already
cold to bring it to a place which is already hot.
Is this factor irrelevant?
It seems relevant to me:
I have tried to put plastic sheets so to drive hot air from the servers
to the input of the conditioners, preventing it to mix to the cold air
output from the conditioners. This gave hotter air to the conditioners
(might have been about 10 celsius hotter, I am not sure). They appeared
to work much more efficiently, like 50% more efficiently, but I have not
tested this really well to be so sure.
If everything was not running, how would you test this?
Like bringing the temperature down then looking at the speed at which
the temperature increases?
It seems like the current conditioners cannot keep the temperature
stable to the temperature which has been preset to them. But I haven't
really tested well.
Yes they are working full time, no cycle.
It might be possible for us to stop all equipment for a while.
Thanks a lot
K
kunt
Do a search on "manual J". I believe there are a few sites with this
calculation in an excel spread sheet..... loads.
Great! Really helpful, thanks a lot!
BTW a delta of 8c is only 14f (24c = 75.2f, 32c = 89.6f) you don't add
the 32 unless you are speaking of an absolute temperature. The 46f
threw me for a second.
OF COURSE, stupid me! I used google calc badly. Also see my reply to the
other post...
It's what A/C systems are designed to do. They "compress" heat so it is
actually coming out of the precipitator at a higher temperature than it
entered the evaporator. Stick your hand in the air flow out from the A/C
outside and you will see it is hot.
That would help if you don't mind the rest of the room operating at a
higher temperature.
The timing of temperature rise under varying external conditions would give
some clue as to the rate the heat comes into the building from outside. If
you can do it with all computers off, that's more accurate. But I guess
you don't have that option.
| really tested well.
You should also look at whether they have the correct blower sizing, and
that they are operating with all other conditions in good shape. Make sure
the precipitator baffles are clear. Make sure the freon is in good state.
If you have air in the freon line, that can reduce efficiency. If you hear
the compressor working really hard right when it kicks on, there may be air
in there (which cannot be compressed to a liquid).
Good thermal testing might take a couple days. I doubt you can do this
with things turned off.
Someone with experience in A/C systems and building insulation might be
able to give you a good estimate of your building efficiency, and adjust
your new A/C sizing appropriately. But my guess is you will need 50% to
100% more than what you have now.
I would also figure in redundancy at this time, too. In one place I used
to work, we made a conservative heating estimate and figured 2 units to
cool it, but installed 3 units anyway for backup purpose so we could take
one unit out of service at any time. I've heard of some places going to
250% to 300% for high redundancy (they were uptime critical).
K
kunt
I understand that it's what they are supposed to do, and approximately
how they work, but are you sure that the efficiency of the AC is not
influenced by the temperature difference between the room and the outside?
I kinda understand the steps involved in determining the heat flow
through the walls due to the temp difference, what I don't know how to
keep into account is the decrease in efficiency in the AC system if the
room where to draw heat from is 8 celsius below the outside temp
Thanks for your help
James Sweet
I understand that it's what they are supposed to do, and approximately how
I kinda understand the steps involved in determining the heat flow through
the walls due to the temp difference, what I don't know how to keep into
account is the decrease in efficiency in the AC system if the room where
Yes, it is. Amperage draw of the compressor increases with head pressure,
which increases with the temperature of the condenser.
While calculations can be done to put you in the ballpark, the final choice
of capacity is an educated guess. There's too many variables involved and
any unit will only be ideal under one set of conditions.
That depends on what kind of efficiency you mean. Sure, if the outside is
hotter on one day than another, the A/C has to work harder on that hot day.
This is due both to the greater heat flow coming in, as well as the lesser
temperature difference at the precipitator. But this is a working condition
and not a part of the equipment efficiency. But maybe what you are wanting
is a working efficiency level.
If the inside room temperature equals the outside, there is no heat to move.
Heat the room up and it flows outside. The flow will be in proportion to
the temperature difference. The details of the building insulation itself
would give you some absolute figures (if you want to spend all the time to
model every aspects of the building construction). Normally one would want
a computer room to be at some specific temperature, such as 18C. Then you
have to consider the extra heat coming in, and opposing the precipitator,
at the highest outside temperature you need to handle. The heat released
by the computers usually well exceeds the heat ingress through the building
in a typical computer room installation. You need enough A/C to keep the
room cold if it didn't have computers, plus enough A/C to remove the heat
released by the computers, plus a level of redundancy to handle taking a
unit or two offline for maintenance or failure.
What is your highest outside temperature? Are you in Troms? Norway?
| 8 c is not that big a delta inside to outside unless you are using
| full fresh air makup. That is still mostly affected by the building
| insulation. The high side of the freon loop will still be
| significantly hotter than the ambient.
Based on his email address, he appears to be located in Norway. Just how
far north is the next question. A/C experts in Lappland might be hard to
find.
K
kunt
No I am sorry, my email is a bogus fake address, I hate being traced so
I morph frequently.
Latitude is that of Lyon, France. Temperature max reaches 40 Celsius in
summer, we want to keep it below 32 C.
Thanks everybody
| I morph frequently.
So I wonder who is getting a bunch of questions in their mailbox.
If you want to morph you own email to avoid spammers, you can do that.
But one should not just use a valid address that could be used by someone
else. Either use a non-existant top level domain or "example.com".
