JeroenH said:
If I have a 30Wp panel and I concentrate sunlight onto it using shiny
panels, what effect would that have on:
1) The produced power level?
Power is generally a function of illumination. Double the light that
falls on the panel and you double the power. There are other factors,
of course. One is heat. The higher the panel temperature then the less
efficient it becomes and the less power it produces for X amount of
light. Typically, if you increase the illumination you also wind up
increasing the heat so the light and power levels don't track exactly.
2) The lifespan of the panel?
From what I'm told, heat is what generally does a panel in. If it gets
too hot then you wind up melting the solder joins and such things in
the panel. Most panels also use an encapsulant that does not respond
well to elevated temperatures and will turn brown over time.
Reports are that you're generally safe at concentration levels up to
about 2X (two suns, or double the amount of light that normally falls
on the panel) as long as it's got plenty of air circulation. Anything
over this and you might want to think about cooling the panels, adding
some form of over temp protection or just accept that it's life span
will probably be compromised.
Anthony
