Concentrating conventional cells.
Discussion in 'Photovoltaics' started by Ian Stirling, Aug 27, 2003.
  1. Ian Stirling
    Ian Stirling Guest
    How do conventional mono/polycrystalline ~100mm diameter cells work when
    concentrated sunlight is fed at them? (say 4-6 times, with adequate cooling
    from the back)
    Is there any way to improve the performance?
    http://inquisitor.i.am/ | mailto: | Ian Stirling.
    "The device every conquerer, yes, every altruistic liberator should be required
    to wear on his shield... is a little girl and her kitten, at ground zero"
    - Sir Dominic Flandry in Poul Andersons 'A Knight of Ghosts and Shadows'
  2. Ian Stirling
    Ian Stirling Guest
    I am planning to use bare cells, and make my own panels.
    Annoyingly, the vendor I was planning to order them from seems to have
    outrageous shipping rates ($80 for a $40 1lb order to the UK).
    Do you happen to know a vendor other than http://www.siliconsolar.com/ ?
    Monocrystalline or Poly, even broken bits to play with.
