Concentrating an LEDs output.
Discussion in 'Electronic Basics' started by Rubicon, Sep 2, 2003.
  1. Rubicon
    Rubicon Guest
    Hello,
    What is the best method for concentrating the flux of an LED into a
    tighter beam? In this instance the LED is an infrared type.
    I've noticed that with visible spectrum LEDs when you aim them
    directly at a sensor the wire bond to the LED chip causes a dark spot
    in the flux. Sometimes according to its make the reflector cup and
    thus the spot is off centre but more often than not it's right in the
    middle.
    I was thinking of perhaps a lens system but are there other solutions
    in use? Have any of you encounted this irritation?
    I realise that I could simply offset the LED but it annoys me that
    only a small part of the flux is then being used.
    Cheers,
    Andrew.
    Remove the ZZ from E-Mail address to contact me.
