Computer power supply question
P
peter
I bought another AT power supply to replace one in an old computer (I
needed to get some data out of it!). Everything matches up on the new
power supply except for the actual on/ off switch wiring for the front
of the computer. The old switch has only for wires going into it (the
switch config\colour codes and so on are clearly marked on the old
power supply), and these wires obviously lead back into the power
supply. The new power supply came with a switch with the same four
wires on it all connected, but on this one there's a small green wire
with small hole connection, and all five wires go into the power
supply. I assume its an earth to be connected? If so, then why didn't
my old supply unit have one? And is the voltage AC or DC going into
this switch? I don't want to muck around with connecting strange
earth,wires to cases and make the bloody thing live or something! Can
anyone shed some light on this for me
T
the Wiz
Green wire with round terminal = earth connection (ground connection in this
former colony ;-)
More about me: http://www.jecarter.com/
VB3/VB6/C/PowerBasic source code: http://www.jecarter.com/programs.html
Freeware for the Palm with NS Basic source code: http://nsb.jecarter.com
Drivers for Pablo graphics tablet and JamCam cameras: http://home.earthlink.net/~mwbt/
Email here: http://www.jecarter.com/contactme.htm
R
Rheilly Phoull
If you have an ohmeter why not measure the resistance (on low ohms scale)
between the earth pin and the green wire ? odds on it would be very low thus
making it an earth wire as found on many cases.
Coming from a PSU any wire with a connecting lug would almost certainly be
earth, besides what else would be enclosed in the switch cable sleeve ?
If you are still uncertain ask the place you bought it from.
