C
Christian Brunschen
Greetings everyone,
First of all, let me admit that I am very much a software kind of person,
and I expect that everybody here knows the old saying,
'The three most dangerous things in the world are a programmer with a
soldering iron, a hardware type with a program patch, and a user with an
idea'
which puts me among the first in that short list. So, fair warning has
been given. Nevertheless, I shall brave my own foolishness and request
your enlightened insight and, possibly, assistance.
I have a Mac mini which I want to set up as the nerve centre of my home -
including as a dial-in server, fax and phone answering machine. The Mac
mini has a built-in modem, so the dialing-in and faxing part is covered.
However, the modem does not have voice functionality; so I need something
else to connect the phone line to the Mac.
I have, in my 'research' (and I'm using this term very loosely, since it
includes mainly googling for possibly useful phrases), come across two
companies that make just that kind of device - but alas, only available as
part of a product including software:
<http://www.parliant.com/phonevalet/>
<http://ovolab.com/phlink/>
Both of these offer a combination offer of a hardware device that connects
the phone line to a Mac's USB port. However, both of these companies only
offer the device in question in a bundle with their software - which I
don't really want, being a software type (as I mentioned) and reasonably
happy to attack that part of the issue myself. So, I'm thinking about
building such a device myself.
I've looked a bit further (in other words, more googling) and come up with
an outline for what I need:
1) a DAA (Data Access Arrangement), with a phone hybrid (2-to-4-wire
converter), to interface the 4-wire audio that I want, to the 2-wire
phone line (one that works specifically in the UK, where I happen to
live at this time, so one that conforms to CTR21)
2) a USB audio CODEC, to convert from the audio to USB
[ Note: I am making the assumption that this device will always be used on
parallel with a modem, or other device which can go off-hook, and thus
doesn't need to concern itself with such matters. This should simplify
the device, because it can simply provide a straight-through audio path,
without having to worry about other control functions. ]
Looking for DAAs, I found the following:
- Mitel MH88422 - seems to do what I want
- Infineon DAA2000 - a two-chip chipset
- Xecom XE0092 - only certified for use in the US, not UK
- Xecom 103X - certified for UK use, but lacks a 4-to-2 wire converter
- Cermetek CH1837 and CH1840, both approved for US but not UK
Of these, the Mitem MH88422 looks nice and simple and straightforward, and
does exactly what I need it do do, without including more features that I
*don't* need.
On the USB audio codec, there are options such as:
- Texas Instruments PCM2900 - USB audio CODEC (stereo, but oh well)
- Philips UDA1325 - similar, but available as SDIP as well as for
surface-mounting
- CMedia CM108 - similar to TI PCM2900
Of these, the PCM2900 looks like a nice, modern chip, but is only
available in surface-mount packaging, and though I have soldered the odd
thing, I'm not sure how great that is for me in the longer run. Oh well.
Now, assuming I'd use something like a combination of the Mitel MH88422
and a TI PCM2900, I'd obviously also need a few other bits and bobs - such
as power. The USB bus helpfully provides some, which I was planning on
using (rather than stealing it from the phone line, which would be
another, though less good, option).
It is at this point that I reach the boundaries of my limited knowledge
and skills in this area, and would appreciate insight, comments, even
assistance from anyone who might be inclined to offer such.
Or, to phrase it more clearly: 'What do I do now? Help! Please!' Anything
you could add would be much appreciated.
Best wishes,
// Christian Brunschen
idea'
*don't* need.
surface-mounting
Best wishes,
