Computer flash ROM.
Discussion in 'Misc Electronics' started by sds, May 31, 2005.
  1. sds
    sds Guest
    I'm used to "hot swapping" for reprogramming lost BIOS on computer
    mainboards.
    (For those who are not familliar with it: you start a working board with its
    own BIOS and swap the flash ROM for the one you need to program.)
    I have one with a 4Mb flash i would like to re-write using this method but
    all the working boards i have only have 2Mb flash... so the question is: If
    i pop the 4Mb in, will i be able to write the whole 4Mb or will i be stuck
    half way ?
  2. sds
    sds Guest
    Just forgot to say they are both PLCC cases.
  3. Guest
    It worked when I tried it many years ago. Check that the chips have the
    same pinout though.
    -A
    "Bother" said Pooh, as the laser vaporised his remaining eye...
  4. sds
    sds Guest
    Pin 1 is #Reset on the 29f002 and A18 on the 29f004 so i don't see how it
    can be done on a board that is made for 29f002.
  5. Spajky
    Spajky Guest
    there were certain MoBo around that could use both types of chips;
    there is a need to search for specs of the existing MoBo on the Net,
    if it supports eventually also a 4Mb chip ...
