Computer (CRT) Screen affected by Magnet
Discussion in 'Electronic Repair' started by JagMan, Jan 22, 2006.
  1. JagMan
    JagMan Guest
    I have a computer (CRT) screen in my possession that has a lightly
    effected area caused by a magnet. Degauss does not help. A co-worker
    told me once that he used another magnet to fix the problem. I don't
    want to do anymore damage to the screen. Any suggestions?
  2. Rick S.
    Rick S. Guest
    Call your local computer repair shop and ask them if you can
    borrow their degaussing coil. Search Google for instructions
    on how to use it.
    Or just take the monitor in and let them fix it. It's a 30-second
    procedure, and if they want to charge you more than $10 keep
    looking for another repair shop.
  3. Guest
    Since you didn't post the make/model/type of crt screen, I will guess
    it has a Trinitron crt in it.
    In which case a strong magnet may have permanently damaged the
    aperature grill or messed up the internal magnets that do the baseline
    convergence and geometry correction.
    Since it is a monitor and not a tv set, the actual jigs and time
    required to correct the problem if a basic degauss did not fix it will
    not be cheap. Should run around $45-50 to do it right.
    Are you sure the crt had not been dropped and the aperature grill or
    shadow mask warped in one corner?
  4. JANA
    JANA Guest
    Did you try degaussing the screen with a hand held type degausser? There is
    a chance that the shadow mask in the tube has been damaged.
    I am assuming that nobody messed with the convergence and purity ring
    magnets on the rear (neck) of the CRT.
    JANA
    _____
  5. JagMan
    JagMan Guest
    I believe that it happened during the transport of the monitor from my
    stepfather's house to my apartment. He just got a new Ford F-150 that
    has a built in subwoofer under the rear driver's side seat. During
    transport, he placed the monitor screen down on the seat. After about a
    45min trip, I think the subwoofer may have lightly induced the screen.
    It is only visible on an all white screen such as a MS Word document.
    The degauss method I used was the degauss button on the monitor itself.
  6. Guest
    A manual degauss may work then. The caveat here is that a monitor or
    tv screen generally should never be shipped in a face down position.
    If a bump had been hit very hard in the truck it still could have
    (unlikely but possible) jarred the shadow mask or more likely the
    aperature grille hard enough to slightly warp it, espcially while it
    was being pulled by a strong magnetic field.
    A manual deguass sometimes can be performed with a magnetic tape eraser
    that plugs in to the ac line. More likely it will need to be performed
    with the manual big round hand wand. If it is a trinitron crt with
    aperature grille, whoever does the degauss needs to be aware that too
    strong of a degausser can damage the tube. In other words they need to
    start far away with a solid red image on screen and come closer to the
    tube just past the point where the color purity problem is resolved,
    then back away to finish the deguass. Never, ever start a degauss on a
    trinitron tube with the degausser right next to the crt.
  7. James Sweet
    James Sweet Guest
    An external degauss coil should fix you up, or maybe repeated attempts
    with the internal one, but let it cool for a couple minutes between
    tries. The built in ones aren't very powerful.
  8. Jamie
    Jamie Guest
    run an AC mag over the screen in circular motions and with draw
    it from the center.
    its most likely that the magnet on the large speaker was near it.
