Computer Case fans
Discussion in 'Electronic Basics' started by kingeric2206, Feb 26, 2009.
  1. kingeric2206
    kingeric2206 Guest
    So I bought a case from someone off of craigslist but it didnt come
    with rear fans. How can I tell which size i need
  2. Lord Garth
    Lord Garth Guest
    Compare it to the power supply fan...
    If it's the same, that's likely 80mm if it's bigger, that's likely 120mm
  3. Baron
    Baron Guest
    Lord Garth Inscribed thus:
    I would also ask the question "Do I really need a fan" ! An awful lot
    of the time you do but not necessarally at the rear of the case. The
    PSU fan is very good at extracting heat from the top of the case. Its
    the hot spots that you should target with an additional fan !
  4. kingeric2206
    kingeric2206 Guest
    alright well i got the 120mm and its too big so it must be the 80mm
    thanks guys
  5. Lord Garth
    Lord Garth Guest
    thanks guys
    Try to find a ball bearing fan as opposed to a sleeve bearing. These
    will run quiet for longer. Nidec makes good fans.
