Lord Garth said:
The video signal will not exceed 1 volt peak to peak amplitude. The 75
ohm part is the impedance of a typical video system. Unbalanced means
it is not a differential signal, one side is referenced to ground and
terminated means there is a matching (75 ohm) load at the receiver.
Very close, but I have to point out one item that might otherwise
lead to some confusion when you're viewing this stuff on a
'scope.
The 1 Vp-p amplitude for a composite signal is for the most
negative-going portion of the signal (the tip of the sync pulse)
to the reference white level. A composite signal which includes
color information (using any of the standard encoding methods,
i.e., NTSC, PAL, or SECAM) may actually exceed the white
level by some amount, making the overall signal somewhat
greater than 1 Vp-p when properly set. In other words, the
1 Vp-p actually applies only to the "black-and-white" (luminance,
or Y) part of the signal. In the worst case condition for the
"100%" NTSC signal (NTSC 100/7.5/100/7.5), a fully-saturated
yellow will take the signal to a bit over 30% above the white
level at its peak. (As this goes over the overload limit for a broadcast
video transmitter, such signals are NOT seen in those applications.)
You may also run into situations in which the chrominance
level is intentionally limited for saturated yellows and cyans,
such that the signal does NOT significantly exceed the white
level ever; this is done specifically to avoid the overload problems.
Per the original U.S. version of the 1Vp-p standard, white is
supposed to be 0.714V above the reference level (blanking),
while the sync tips are 0.286V below this level. Standard
European practice simplified this to +0.700V/-0.300V.
Bob M.
